Hi , I've recently moved into a propery with an electric shower installed , there is no isolation switch in the bathroom, the showers seems to be wired directly from the consumer unit , it is on its own supply and can be isolated at the board , is this sufficient to pass an electrical test ? Or will I need an electrician to fit a double pole isolation point for the shower ?
Regards
Regards
