Pepe
I want to add a second light and a second socket to an additional lighting and power circuit in a family members garage.
Currently the power circuit is connected into a 16a MCB in the consumer unit in the garage. This is then connected to a 16a MCB in the main consumer unit in the house via SWA.
The appliances in the garage are a fridge, a chest freezer and a tumble dryer.
My calculations with diversity works out at about 18.8 amps of current.
I think i should swap the 16amp MCB's to 20 amp MCB for garage and 32 amp for the main consumer unit.
The lighting circuit only has two lights. Works out about 0.5 amp drawn.
Any advice would be greatly appreciated.
Also on a separate note. Is it acceptable to terminate Swa cable without a gland and piranha nut? It is just taped into the bottom of the consumer unit.
Also the installer has drilled holes in plastic pattress boxes and feed t&e into the boxes leaving gaps for dust to fall into! Again is this acceptable?
I don't think so, having just done the Level 2 2365 and 17th edition. But just wanted other opinions, as I'm still rather inexperienced.
Cheers for reading
Pete
Cheers for reading
Pete
