Is a main double pole switch a linked switch? | on ElectriciansForums
Discuss Is a main double pole switch a linked switch? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
N
nazoom
Hi
I am trying to fill in the Condition Report Inspection Schedule For Domestic and Similar Premises With Up To 100 A Supply. For a single phase installation. The part that I am enquiring is in Section 4.0 Consumer Unit/ Distribution Board, part 4.7 that states " Presence of main linked switch" In my installation there is a double pole main switch. Is this a Linked Switch? or does it have to be three pole switch that operate all the the three poles together at the same time?
The link refered to is so that both L & N are switched at the same time. So the main double pole switch meets that reqt.
I'm assuming this is single phase only, so not sure what you mean by three poles? .
Reply to Is a main double pole switch a linked switch? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
