Is a mother board first fix or second fix | on ElectriciansForums
Discuss Is a mother board first fix or second fix in the DIY Electrical Advice area at ElectriciansForums.net
dandalion
Hi
I am a property developer currently doing a development of some flats.
The contractor was to provide first fix electrics. He is saying this doesnt include the mother board and all the bit within it (I am not sure of the technical terms). but it seems to me that a mother board should be first fix.
grateful for any advice.
Many thanks,
Leo
Welcome to the forum. If the sparky has quoted for first fix of the flats, that is what he has quoted for. The main DB/main board and the running of cables to the flats or the local main boards are a different matter.
Think of it like a road system..... Motorway = Main board leading to an....
'A' road = main board for that floor leading to......
a Cul de Sac = The flat!
What did you ask him to first fix? Just the flats or the cabling for the mains to each floor + the boards?
Hi
Many thanks,
Leo
By mother board I assume you mean distribution board/consumer unit...that's normally 2nd fix, unless it is a flush unit. First fix is cables and flush boxes installed to enable walls/ceilings to be boarded and plastered.
the first fix would include cables to the DB or CU. any equipment or accessories come under 2nd fix and commissioning.
Hi
Many thanks,
Leo
why should the "mother board" be part of the first fix?
Surely you have contracted him to do the 2nd fix too?
First fix is throwing a few cables around, back boxes etc. Second fix is fitting out plus CU.
Think the OP wants the 1st DB up and running for temporary + the 110V supplies for the trades. That is another set of works and another quote (just reading in-between the lines lads).
Throwing a few cables around? Don't make it sound too easy, people will try to go to college for 5 weeks and have a bash!! Oh wait.........
I was thinking about asking him if he had a temporary supply!
Lets play nicely Gentlemen or this will be sent to the DIY section.
Whit, banter and jovial is cool. Calm down on the rest before it starts lol.
Which is exactly where it belongs!
Not just yet dave. The Op is not a DIYer, he is a developer asking about a quote he has received. If this thread needs to be transferred into the DIY section due to members giving sarcastic remarks, it will do and the members will be noticed (yet again).
If any member has a problem with any thread or post, please feel free to hit the report button.
This thread is a good example of when a thread should "have a lock down" where only the OP & the mods can contribute....
Reply to Is a mother board first fix or second fix in the DIY Electrical Advice area at ElectriciansForums.net
M
Bathroom first/second fix plumbing costs Hi all, I just got a quote for bathroom and WC plumbing LABOUR only first and second fix ÂŁ3850 for the...
midaslegend
M
J
Riven Slate: use sand/cement or adhesive - is there a definitive answer Hi - my builders bedded 10-12 mm brazilian riven slate on a sand cement...
Jim Rickards
J
