B
Ben Simpson
I'm looking to swap out my light fittings from gu4 to gu10 and to do so I have to cut a transformer off and wire the mains into the gu10 fitting. It's an old flat and all I can find within it (in terms of power isolation) is an RCD. Will an RCD device provide enough protection to perform this task? Or do I need to isolate in some other way?
Thanks in advance for any advice.
