Is blocking an extractor fan dangerous? | on ElectriciansForums
Discuss Is blocking an extractor fan dangerous? in the UK Electrical Forum area at ElectriciansForums.net
Status
Not open for further replies.
Ireland
Our extractor fan was making a very loud noise when it is on. Stopped this by putting more pressure on it with duct tape but means it is stopping the fan from moving. Is there any problems with blocking the extractor fan from moving? Will it short circuit or anything?
If the impeller has jammed the fan motor Could overheat when it is switched on and ignite, I say COULD IGNITE, best to get it checked out by an Electrician, or switch it OFF in the mean time.
This is what I’ve done. A little bit of pressure on the middle is the only way to stop the noise. But stops the fan from moving. Fan is very weak also anyway
  • [ElectriciansForums.net] Is blocking an extractor fan dangerous?
that fan looks like a relic from Dad's Army. get a spark to replace it ( or do it yourself if you are competent to do it ).
Most domestic fan motors are impedance protected so they shouldn't overheat to the point of combustion under lock rotor conditions. I still think what you've done is a bad idea though because I don't trust the ratings and compliance of cheap motors from the Far East and I've personally encountered more than one domestic bathroom fan that caught fire in the past.
If there's no isolator switch next to the fan rather get someone in to remove and disconnect the fan.
Reactions: DPG
Status
Reply to Is blocking an extractor fan dangerous? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
