Discharged
Why is mains domestic power referred to as either 230v or 240v? Why not settle on just one of them? (My limited knowledge tells me that the reality is usually 243v or 237v - is that right?)
Cheers.
Cheers.
Discuss is it 230v or 240v? in the Australia area at ElectriciansForums.net
230v is to bring us in line with europe and 240 is what our power stations kick out.
I think you'll find that it used to be 240V + or - 10%.The supply industry has actually done nothing physical to reduce the nominal supply voltage from 240V to 230V, it's still 240V open circuit at the terminals of the local supply transformer. What has changed, as part of European harmonisation (Cenelec HD472), the declared nominal voltage has changed from 240v +-6% (between 225.6 and 254.4V) to 230V +10% -6% (between 216.2 and 253V), very little change, just a slightly wider margin at the lower end. This suits the DNO's just fine as it gives them a bigger window of acceptable supply voltage in rural areas, without the associated costs rewinding transformers or tap changing.
Note:- A second round of change in the declared nominal supply voltage (Cenelec HD472-S2) 230V +-10% is pending, it was due on 1/1/2008 but has yet to be implemented in the UK.
The 6% only came in with the change to 230V.
If you do the calculations, you'll find both come out at 216V.
The only thing that has really changed, is that the suppliers are now not allowed to supply a voltage over 253V, whereas in the past they were allowed up to 264V.
I always thought it was 230 +/- 10%, so 217 to 253...
Reply to is it 230v or 240v? in the Australia area at ElectriciansForums.net
