Is it called an accessory back box? | on ElectriciansForums
Discuss Is it called an accessory back box? in the Talk Electrician area at ElectriciansForums.net
North Somerset
Hi, Just wondering if anybody knows what the proper name for a metal back box with a single and double space in one complete box is called, and who makes it. Many Thanks. :eek:
Various - back box, metal clad what you want really and made by seveal. Usually find with the cheaper versions the threads are rubbish just bear that in mind.
Some variations here:
Boxes and Enclosures
Thanks for replies. I have used them before, just wondered if there was a porper name, but obviously not. Must be one of those things you just say to the wholesaler "you know one of them boxes with a double and single in one box" :-D
I've never seen a double and single in one box before only two singles. Is there such a box with three doubles available as when I'm doing the TV area of a lounge getting three doubles next to each other, exactly the same height and level is a pain in the ar5e?!
never seen a triple box , with lugs so you can have say > single skt , fuse spur and tv point in ......... seen boxes for a triple skt but thats about all .
no lugs in the middle , that's a triple skt box , no good for fitting 3 different units to .,,, what were looking for is something like a duel box , but able to accept another unit > 1 spare , 1 single skt . 1 tv point , all in the one long box , but i don't think the exist
cheers
you can get interconnecting ones made by click . and as a tv is usually in a corner i put one on one side of the wall and two on the other makes it a bit easier and still looks fine plus when the telly is there you cant usually see them.
Alternatively you could use three sperate single boxes and connect them together using a coupler & male bush, making them one unit.
Reply to Is it called an accessory back box? in the Talk Electrician area at ElectriciansForums.net
Thanks Brian. I'll keep doing it then, no harm I suppose. I am lucky in that being DIY, I have the luxury of time when it comes to this kind of...
An opamp problem: - At +input I have a 424uV!!! signal. I diminuate it as much as I could to be clear that it is not the interference problem. You...
