Hi all
recently while testing a factory ive had an issue with one of the DBs.
When i connect my kewtech meter to do Zdb, the phase-neutral logo appears and the meter is beeping, won't give a voltage reading and won't test the loop.
I was told this could be due to an air compressor or welder on one of the circuits creating a backfeed...but i get the same trouble if i try to connect the earth and neutral leads both to the earth terminal, which is missing out the neutral.
anyone had this problem?
