EzioSuffolk
Is this a common requirement for a dimmable light switch?...
I know there's push on/off dimmer switches, but it seems inevitable to me that the dimmer setting changes a little (i.e. the knob rotates a bit) whenever it's switched on/off.
I want the lighting level to be controllable (i.e. dimmable) occasionally, but for the great majority of the time I want it left precisely as it is! I certianly do not want a dimmer that 'switches on at the start of its rotation, and then steadily increases in brightness', because that would necessitate carefully adjusting it every single time!
So, what I think I want is a normal (on/off) light switch mounted adjacently and in series with a dimmer.
Does that make sense? Is it a reasonable/common requirement?
Thanks for any help or advice.
