E
electricans_son
Many of my items have failed recently and as my gas central heating boiler is 20 years old, I am concerned about that failing too, although it works perfectly at the moment. I occasionally go away for a week and in addition to leaving the gas central heating on at a low temperature, I am thinking of leaving a convertor heater on, in the bedroom immediately under the cold water storage tank while I am away. This bedroom is also adjacent to the airing cupboard. Details of the heater and position:-
Automatic overheating cut-out,
Metal sides, but plastic grill top and feet,
Set at the lowest of two heat/kW inputs, the maximum is 2 kW,
Thermostatically controlled to give a constant room temperature of say about 8 degrees 24/7,
Placed about 20 cm from the wall ("egg box" type) and 80 cm from the bed, and parallel to both,
Fan not turned on.
My intention is to leave only if the daytime temperature is well above zero and would come back if the daytime temperature drops to zero or below, or the night time temperature is exceeding low, but that may take a day or two.
I realise that an oil filled radiator is probably the safest, but they are inefficient and I believe expensive to run.
Any advise please?
Fan not turned on.
Any advise please?
