Hello, first time posting here. I have been using multiple different products to try and get rid of blocked shower drain, i.e. mr muscle / vinegar / boiling water all sort of things but it seems like its temporary solution where it works for the first 1-2 showers and then its stuck again. I purchased the plastic drain snakes from Amazon and tried using it, it went half way through but upon returning it couldn't grab anything, I also got the steel version but it was too thick to go in.
I wanted to unscrew the thing in the shower drain but it seems like its screwed to the pipe? That's where my worry is, would it be safe to unscrew and try to get the hair out somehow? It seems the pipe is sideways or something. Attaching photos
I am renting this property and moving out in couple of months so if its unsafe I will let that be, the water flows but incredibly slow, so if possible I would want to clean it properly
Continue reading...
Continue reading...
