is it safe to use this plug? | on ElectriciansForums
Discuss is it safe to use this plug? in the UK Electrical Forum area at ElectriciansForums.net
dublin
as far as I can, some of the back is missing but the electrics seem intact?
  • [ElectriciansForums.net] is it safe to use this plug?
thanks guys
fyi i found this in a rental and wasnt sure if they had been using it or not. i just moved in.
you will be horrified to know that before posting the pic i plugged it in and then plugged it out (after turning off the swtich)
if i want to replace it is that an easy job to get a new top or is it more the case that i need a whole new plug and cable
thanks guys
It's highly doubtful that you will be able to purchase just a replacement cover for it. The whole thing would need replaced.
thanks guys
It's just a simple case of fitting a new plug to the existing flex.
Reply to is it safe to use this plug? in the UK Electrical Forum area at ElectriciansForums.net
Haha yes, it is. Must be a northern expression. Have a Google 😂
Probably for an old TV amp as little spark said
