Discuss Is Landlord certificates same as PIR? in the Australia area at ElectriciansForums.net
agree^^^.
Sorry mate disagree.
You can only issue any one or a combination of:-
1, Electrical Installation Certificate for an electrical installation, with schedule of test results and Inspections.
2, Periodic Inspection Report for an Electrical Installation, with schedule of test results and inspections
3, Minor Electrical installation Works certificate.
No other documents exist for Electrical Installation work, and any made up forms of any type are not worth the paper they are written on, whether they are NIC, IET etc etc. if they are not in the BRB then they carry no worth whatsoever.
If you do a visual inspection for whatever reason, then this should be noted in the Extent and Limitations box of the PIR form. You would still need to complete the Inspection schedule, and the test result sheet, but obviously on the latter, you would list the circuits, and put untested.
Cheers..........Howard
Reply to Is Landlord certificates same as PIR? in the Australia area at ElectriciansForums.net
