Always learnin
I know I shouldn't doubt a company like Bosch but some reassurance or suggestions from anyone here would help ease my mind.
We've purchased a Bosch induction hob (Model Number PIE651BB1E/17) it comes with a 5 core flexible mains cable about 2 metres in length. I'm ok with the wiring aspect of the 5 core cable as the instructions are perfectly clear. Each cable appears to be 1.5mm sq (this is printed on the cable sheath - Deja HO5V2V2-F 5G 1.50mm TS EN 50525-2-11). The wiring is basically 2 live (brown and black) and 2 negatives (blue and grey) plus an earth.
The hob is rated at 7400 watts and a 32amp MCB recommended.
Last year an electrician changed our consumer unit and installed a separate 32 amp circuit for the previous old ceramic hob. That work is all signed off and certificated.
My concern is that the cables for the new replacement hob appear to be only 1.5mm sq and even though there are 2 of each, is 3mm sq cable up to carrying 32 amps?
I'd welcome any reassurances, or even suggestions that maybe upgrading to a 5 core 2.5mm sq cable might be better or am I just being daft?
- TL;DR
- Bosch induction hob (7400 watts). Five core (1.5mm) cable supplied by Bosch. Is that up to the job or should I look to find 5 core 2.5mm cable?
