A
alex h
I bought a fluke 87v multimeter about 2 years ago, it's barely been used as I use the company's test equipment on site. Recently got it out to check some electronics for a home project an i'm not sure if it's reading properly. When testing on ohms, the leads won't zero when touched together, eventually settling at .6 of an ohm and when I tried to measure the resistance of a headphone jack, the readings were very erratic and wouldn't settle for ages. Is this usual? Can't believe a fluke tester would be so inaccurate...
