Is my supply up to it | on ElectriciansForums
Discuss Is my supply up to it in the Australia area at ElectriciansForums.net
B
badllad
Fitting an electric shower and am waiting for a sparky to connect new shower CU to meter.
Checked meter and it is only rated at 40A 240V. Fuse is marked as 60A. Existing CU rated at 80A.
Will I need to get DNO to upgrade meter?
I checked website for local DNO which is NEDL. It says any query on meter should be referred to supplier (British Gas). I have seen in other posts that DNO should be responsible for upgrade. Which is right?
Hi mate I just had my brothers upgraded BG will replace the meter for a digital meter and if you ask for them to upgrade tails and fuse and they fitted a wylex 100Amp main isolator switch at the same time its ÂŁ39 all in wether you have one or all replaced
Reply to Is my supply up to it in the Australia area at ElectriciansForums.net
Hello all. I have been asked to fit a Ryefield board and switch-fuse on an existing 3 phase supply so that a shop can have its own meter and 3...
Agreed, i have a cabin in the woods, water heating and hob is via 19Kg propane bottles, lasts ages and space heating is via warm air heaters via...
