Is Panel Angle REALLY That Big of a Deal? (My Installers Were Pretty Relaxed...) | on ElectriciansForums
Discuss Is Panel Angle REALLY That Big of a Deal? (My Installers Were Pretty Relaxed...) in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
United States
So we just had our solar panels installed last week – super exciting! 🎉 But one thing that's been bugging me is the panel angle. The installers weren't super precise, saying it would only make a small difference... but now I'm second-guessing everything!
I've been doing some research on the Internet, but I am not sure whether should I follow them or not and meanwhile I'm worried we're missing out on precious energy! Especially in winter when the sun is lower.
Here's the deal:
Our roof is pretty standard, slight south-facing slope.
The panels are basically flat on the roof, maybe a tiny tilt.
Have I messed up by not demanding a steeper angle? Help a nervous solar newbie out! 🙏
What I want to know from YOU:
How much difference does panel angle ACTUALLY make in your experience?
Did you obsess over it during installation, or go with the flow?
Pics of your setup (and maybe even energy output data) would be awesome!
Maybe I'm stressing over nothing, but I want to make sure we're getting the most out of our investment!
As long as the roof has a standard slope, (around 45 degrees) I don’t think it matters too much.
It’s only when it’s a flat roof, or on the ground, that panels are fixed to a sloped frame.
There is a limit to how much a panel can put out… so even at optimum angle, no shade and no clouds… the panels can’t make more than they’re capable of…
Likewise, the AC inverter can only put out a certain amount of kW….
Whatever the angle, or size of inverter… you are now enjoying free electricity during the day.
The investment cost will pay back in energy company savings.
While panel angle can affect performance, so does the latitude of the property the panels are installed on, roof orientation, shading from trees and chimneys to list a few factors that need to be considered when designing a system to give the optimum maximised output
I saw on a documentary about the sun and it had a small bit on them where people had them following the sun and the amount of money they'd spent on it they'd never claw the extra back.
Spoke to a bloke on a canal boat who would move it every few hours and he swore it'd double it's usefulness doing it. Would have been a basic thing for charging phones and things mind I don't think it was wired to the boat CU (did I use that right, consumer unit? Lol - I try). Was probably 3x6' on a 10-20% slope.
I fitted a solar panel on a 10m sailing boat a few years back for my brother's brother in law other than shading from the sail occassionally he reports that it is working well and maintains the batteries charge and runs all the electronics without having to run the engine when as sea. The other advantage is he doesn't need to remove the batteries from the boat during the season to recharge them
Reply to Is Panel Angle REALLY That Big of a Deal? (My Installers Were Pretty Relaxed...) in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Crikey that sounds really complicated…. Never fitted Solar but would be interested how you get on … with pics if you can & good luck😎
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
Bury a 4 inch duct under the pathway with drawropes until the time they are needed and pull in the correct size of cable at the time. We would...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
Youre in the same boat as me. I was previously with niceic and later on, napit. No issues. I didn't bother finishing my nvq3 as in 2010 during the...
