.....actually didnt estimate correctly at all) was the actual amount of electric it would save me on a daily basis ......
Yes, now that my own system has been running for a few months, I'm beginning to appreciate that using your own solar power is very difficult because it is so variable from day to day or even from minute to minute.
As you imply: who wants to be staying inside on a lovely sunny day to do the chores?
However, we live and learn.
As far as possible, houses in future ought to be built with a nice roof facing, and preferably so that panels can be mounted on two or three of the roof sides, in order to provide a more even supply of power during the day.
To have 1.2kWp facing in each of East, South and West (for a 3.6kWp system*) would give a much more usable and steady power supply.
It would also not all be in sun at any one time, so a 2.5kW inverter would be able to handle the output from the 3.6kWp, and the inverter would be working at good capacity (more efficient) for longer.
Panels are relatively cheap, so lots of panels in as many compass-point facings as possible, coupled with a medium size inverter would probably be more efficient.
Certainly I have 3.75kWp facing SoutherEast and it runs close to full capacity in mid-morning (3kW+) so there's more power than I can use on a sunny morning, but afternoons I get relatively little power (maybe 0.6kW) and the big inverter is not very efficient when the flow of electricity is just a trickle.
(*I choose 3.6kWp as a number just within the 16A/230V DNO ideal limit).
