Is SPD mandatory for a new circuit? | on ElectriciansForums
Discuss Is SPD mandatory for a new circuit? in the UK Electrical Forum area at ElectriciansForums.net
London
Hi all
I am after some advice on an installation I have coming up.
Its a new TP+N circuit in SWA (13m run clipped direct) for a 22kW Tesla wall charger.
I will be installing a Matt:e unit upstream to provide regs compliant RCD protection & Open Pen protection.
My main question is do I need to install an SPD for this circuit. I cannot find a unit that has SPD protection, meaning I can only install a separate unit (not possible due to space limitation) or install in the existing CU (an old TP+N Eaton CU) or leave it out completely.
Installing a separate SPD unit would mean a the circuit passing through a ridiculous amount of devices.
Main CU MCB ---> SPD UNIT (MCB + SPD) ---> Matt:e unit (MAIN SWITCH, RCD & O-PEN) ---> Wall charger
Any feedback would be much appreciated
You'd have to be mindful of SPD conductor lengths doing it that way.
I think Matt:E make a single board with Type A RCBO, openPEN detection and Type 2 SPD.
e.g ARD-1-40-TP-R-SPD
I have no idea what it costs though.
Without looking at the scenario myself, I find myself looking for ways to avoid the Matt:E, etiher:
1 - accept I'm banging an earth electrode in for the charger (if client has specified Tesla charger) and not connecting the charger to the TN earth.
2 - use a different charger that has open PEN detection
In either case you'd then be down to one enclosure (maybe even a horizontal one) that has Main Switch, SPD, RCD, and MCB.
Reply to Is SPD mandatory for a new circuit? in the UK Electrical Forum area at ElectriciansForums.net
This potential client seems to be making progress in terms of being interested in proper chargers and answering my query questions. I have also...
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
4K
