Is there a flexible pipe suitable for a secondary hot water circulatory system? Discussion Thread | on ElectriciansForums
Discuss Is there a flexible pipe suitable for a secondary hot water circulatory system? Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Is there a flexible pipe suitable for a secondary hot water circulatory system?
Content of the thread: I'd be grateful for some advice please.
I'm doing a stable conversion which requires a secondary circulatory system. The plumber (yes, he is qualified) initially didn't realise this and when questioned, didn't actually appear to know what a secondary system was! He did come back to install one though, but I've now discovered (just in time before the ceilings are boarded over), that the pipework he's fitted, using JG flexible pipe and fittings, is unsuitable for a secondary circulatory system. Replacing his runs in solid copper is going to be a nightmare because part of the system passes through I beams (so will involve lots of short lengths joined together). Does anyone know of a flexible pipe which would be suitable for a secondary hot water system so I can just pull it through to replace the JG stuff?
Thankyou in anticipation.
Is there a flexible pipe suitable for a secondary hot water circulatory system? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Is there a flexible pipe suitable for a secondary hot water circulatory system? Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
A
F&e tank vent pipe pouring hot water Hi all I have an oil fired heating system open vent with an f&e tank we had some problems with air...
Andymav
A
M
Heat pump hot water cylinders Has anyone fit the hot water cylinders with a little heat pump on the top that has ducts to bring inside and outside...
Matt0029
M
