Is there a standalone weatherproof timer? | on ElectriciansForums
Discuss Is there a standalone weatherproof timer? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I am looking for a weatherproof timer to switch a 2 gang socket on/off.
I can find plenty of single sockets that incorporate a timer but I cannot find one with with 2 sockets, or just a separate weatherproof timer (suitable for sockets, 16A) that I could then use to switch a standard 2 gang weatherproof socket.
Does anyone know if anything like this is available?
If at all possible it's far better to put the timeswitch indoors earlier in the circuit, the best way to weatherproof something is to not put it outside.
If it has to go outside then a Din rail mounted timeswitch in a weatherproof enclosure would do the job.
Agree
Reply to Is there a standalone weatherproof timer? in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
