Hi All,
I'm kind of hoping to get confidence in my decision to have spots fitted into the ceiling of our new extension, but keep coming across different advice...help would be welcome!
We're looking to fit 12 LED spots (Aurora Pro 6w) into a lean-to pitched roof, split into two circuits on dimmers. Room is 7.5m x 3.5m
There are Velux windows (3) and there will be 100mm Celotex between joists with 50mm underside of rafters, plaster board to be fitted as finished ceiling...roof is vented between tiles and Celotex.
So, I was going to have holes into the Celotex at 12 positions, the holes being double diameter of light fitting and with about 25mm gap between the rear of the light fitting and the face of the Celotex. There would be at least 25mm of Celotex left in bottom the pocket that is created which separates the LED from the vented roof.
I appreciate it will compromise the thermal integrity, but have seen arguments and statements from various LBC guys accepting that it's not the end of the world in terms of thermals, especially given the use of Velux...is this OK?
Does anyone have an input on the level of protection that's needed from a fire safety perspective, ie...the distance around the fitting?
Any input very welcome.
