Is there such a thing.....? | on ElectriciansForums
Discuss Is there such a thing.....? in the Australia area at ElectriciansForums.net
sythai
Devon, United Kingdom
Hi Chaps...
Just wondering if anyone knows if there is such a thing :
dawn - dusk sensor -----> basically a photocell but in reverse -----> need it to trigger a pond pump to work in daylight hours.
No probs if not time clock it will be, but customer would prefer sensor.
So thought I'd ask.
Many thanks,
Sy
Have a nice weekend - I will when this endless amount of paperwork will go away - up at 05:00 this morning dreaming about work again
Is there any photocells with normally open and normally closed terminals? if not can you install a relay in the circuit so when the photocell is in light and open circuit the relay is de-energised and runs the pump, then when the photocell is energised it switches the relay which will turn the pump off?
sounds a good plan, but may have to experiment with a couple of capacitor values across the relay coil.being inductive, it could upset the photocell.
You might find a standard photocell with a changeover switch instead of the usual normally open if you look around. Here's quite a nice Square D offering but I'm sure theres others.
Thats great thanks Marvo..... done quick google but not the easiest product to get a price on?
Trying to do my quote over weekend, can anyone help me out ?
Doubt it will be cheap being Schneider, but I'm one for quality any day
Reply to Is there such a thing.....? in the Australia area at ElectriciansForums.net
