Is there such thing as a double socket with built in surge protector | on ElectriciansForums
Discuss Is there such thing as a double socket with built in surge protector in the Australia area at ElectriciansForums.net
geordie
Teesside
After a double socket with surge protection to be used to supply a pc. Can you get such a thing.
Reply to Is there such thing as a double socket with built in surge protector in the Australia area at ElectriciansForums.net
these are usually MOV’s metal oxide varistors or sometime spark gaps , these change there resistance with voltage,im fairly sure the lower voltage...
From the title and first post it is not clear whether you are looking to install surge protection or a lightning protection system (LPS) or is it...
