Is this a high frequency batten or HPF? | on ElectriciansForums
Discuss Is this a high frequency batten or HPF? in the DIY Electrical Advice area at ElectriciansForums.net
sensible
I have just bought what I thought was a 'high frequency' fluorescent light for the kitchen, thats what it was advertised as.
It arrived in packaging with 'HPF' on it which is 'High Power factor' which I dont think is high frequency.
I wouldn't be too bothered but it doesn't work! The picture in the description shows a starter, whereas there is nowhere in this fitting to put a starter which makes me think this is a high frequency as I didn't think high frequency has a starter?
Here is a picture of the ballast:
Have tried to upload but cant!
This is what it says:
Electronic ballast, EF-P 2x70W 220-240
In 0.59A
fn 50-60Hz
Power factor 0.98
preheat starting
My guess is it has fitting for a high frequency light (no starter), but a ballast for a HPF? So it doesn't work!
Any advice on if this is a high frequency light and if it needs a starter would be great...
If it's an electronic ballast, then it will be high frequency, and won't need a starter. It is also high power factor (0.98).
If it doesn't work, send it back.
Reply to Is this a high frequency batten or HPF? in the DIY Electrical Advice area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
