Is this a reasonable quote for a couple of jobs? | Page 2 | on ElectriciansForums
Discuss Is this a reasonable quote for a couple of jobs? in the UK Electrical Forum area at ElectriciansForums.net
Hi,
I need to get some work done so that I can get an electrical safety certificate for property.
I called in an Electrician and he suggested that I need to do the following;
1. Replace old fuse box with Consumer unit (ÂŁ350)
2. Upgrade Gas and Water main earthing and bonding (ÂŁ90)
3. Upgrading to all switched sockets and lights (ÂŁ100)
4. Replace bathroom light with a dome fitting type (ÂŁ60)
5. Installation condition report (ÂŁ100)
Would you say that these are reasonable prices?
I'm not sure what amount of work needs to be done for some of them.
1. (Ok) Seems ok?
2. (Unsure) Is this a quick job?
3. (Unsure) I thought everything was switched. Maybe he means making sure that everything is earthed and the wiring is all sorted.
4. (Unsure) Is this just a case of changing the cover? Or wiring the light all in?
5. (Ok) Seems to be the normal price for most reports.
You are paying for the electrician's knowledge and expertise as well as "just a 10-minute job" installing some bonding cables.
That depends how you look at it. I don't think that it is a big job that requires an abundance of knowledge but I could be wrong. That's why I am asking and I will consult other sparks in order to see what they charge. If its the norm then there is not much I can say or do.
Hi,
1. (Ok) Seems ok?
Hum .. Talk about being light on detail ..
Where is the property?
How many circuits?
Dual RCD board or rcbo's
How many switches?
How many sockets?
White ?
Shiny chrome?
A pointless post imho
to save the headache could you put on the forum the estimate .
Ok thank I didn't know that.
Well I will check out some of the other NICEIC approved companies in my area. There are some good ones to choose from so at least that will help me to make a better decision.
So you've taken on board my point that being a member of the niceic is no guarantee of quality, so you'll check out more members of the niceic ?
You'd be better off asking friends and relatives who have had significant electrical work done for their recommendations.
Who lives in a house like this?
Let’s go through the keyhole...
We’ve got a home made lab with a dedicated consumer unit..
We’ve got a fan that has prematurely broken down
The house seems to be occupied by many different people all of which seem to be a bit daft..
And finally a fuse board that needs to be upgraded..possibly due to it being continuously overloaded
Forum, it’s over to you ...
I have my popcorn.
Except I can't actually stand the stuff, bloody chaffy bits always get stuck between teeth and somehow down around your cheeks and gums.
[ElectriciansForums.net] Is this a reasonable quote for a couple of jobs?
Are you for real? Because I would be extremely worried I had to employ you.
I was asking for some advice but I'm sure that I can get better elsewhere.
Reply to Is this a reasonable quote for a couple of jobs? in the UK Electrical Forum area at ElectriciansForums.net
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
