Is this a TNCS PNB? Large Commercial Site with local 11KV Tx | on ElectriciansForums
Discuss Is this a TNCS PNB? Large Commercial Site with local 11KV Tx in the UK Electrical Forum area at ElectriciansForums.net
P
Paultrim123321
Hi All
Sorry for the poor photo's, just after some clarification as to the arrangements at source of the supply below. No info from the DNO with little info available in the sub. Photo 2 clearly show a PEN between the neutral and the earthing bar in the section board. I am presuming this to be PNB but would appreciate some advice please gents. For info, the Tx is 11KV with local metering on the LV side adjacent to the LV Section board.
[ElectriciansForums.net] Is this a TNCS PNB? Large Commercial Site with local 11KV Tx[ElectriciansForums.net] Is this a TNCS PNB? Large Commercial Site with local 11KV Tx
The neutral is linked to earth at either the tx, or in the main panel. Most I've seen are linked in the supply side, in the cable chamber below the ACB.
Although these systems are sometimes called TNC-S, I don't believe that they share any of the characteristics, and I'll stick my neck out here, and u would design bonding as TNS
It’s TN-S standard set up for a MV/LV transformer.
The removable link is purely for “dead” testing. As John said the normal location is on the incoming on the switchgear before the main ACB. Very rarely will the earth link be fitted in the transformer.
Agree with Tony, this a typical TN-S arrangement made at the LV Main Switchboard. If this is a DNO transformer, for area distribution, then the chances are these days, that the neutral will continue to be grounded at every cable joint along the various cable distribution routes.
By the way, that MV cable termination into the Transformer isn't a good one. I'd almost certainly fail it, if presented to me on my project!! lol!!
I’ve just had a close look at the connections in PhotoShop.
There’s no soldered thimbles on the cores. Those clamps will never hold up under load.
The clamps alone can be used for SolidAl conductors but copper needs a thimble sweated on to stop the conductor being squashed and keep a constant contact area.
I’d condemn it out of hand!
Reply to Is this a TNCS PNB? Large Commercial Site with local 11KV Tx in the UK Electrical Forum area at ElectriciansForums.net
