Is this acceptable practice? | on ElectriciansForums
Discuss Is this acceptable practice? in the Australia area at ElectriciansForums.net
B
bathroomboy
Opened an old wylex cu today and there was a 10m cable feeding stand alone breaker for shower fed from live side of main switch together with 25m/m tails is this acceptable practice? myself I would of split the tails.
Its the age old story of 'one point of isolation' for the whole instal, however, many see this as the main service cut out.
Anyway, i would remove the 10mm from the wylex, bin it, and put new 25mm tails for the shower cu and 25mm for the main CU fed from a henly block.
Reply to Is this acceptable practice? in the Australia area at ElectriciansForums.net
