Is this bend in a PEX pipe too much? Hi,
I by chance discovered that amongst a bunch of copper pipes, I have a PEX pipe that runs through a void between the original house and extension. The image is from the back of a store cupboard where the pipes run up and then into the original house between floors.
I suspect this pipe has been in place for at least 12 years, if not more. We have lived here for 5. It was only when I looked up the void, I discovered this bend. Personally, I'd have opted to use an elbow.
Anyway, some might say it's been fine for years don't worry but figured I'd ask.
Thanks in advance.
Is this bend in a PEX pipe too much? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Thanks in advance.
