View the thread, titled "Is this even safe?" which is posted in Electrician Talk | All Countries on Electricians Forums.
I am from Chicago, but am currently in Italy. The building I am living in has 4 meters in a wooden box. I noticed my meter has quite a few more wires than the rest, so I took a closer look.
Meter 4 has a blue and black wire, that are spliced into another blue and black, that run into a tube near the bottom of the large wooden box.
Meter 3 has a brown and black, and 2 blue, with a brown spliced to a brown that goes into a tube, and a blue spiced to a blue that goes into the junction box, and a black and blue that go into a tube along the bottom of the wooden box.
meter 2 (my meter) has 2 black, 1 brown, 2 blue, 1 green/yellow, with the brown, green/yellow, and 1 black going into a long tube that goes out the top of the wooden box and up the wall, and a blue and black going into the junction box.
The junction box then has a brown, a gray, and 2 blue leaving the junction box, into a another tube near the bottom of the wooden box.
meter 1 has 1 black, 1 white that go into a tube, which also has 1 black, 1 blue coming out of it that are just completely cut and dangling.
There is also a tube under meter 1 with 2 brown wires coming out, with one being spiced to a brown wire that goes directly into the junction box, and the other spliced to a blue wire coming out of the tube under the random black box on the side, that leads into the junction box.
Then there is a black metal box on the side, that has 3 brown wires spliced into the wires on the side of meter 1, that go into the junction box.
Something like that. Clearly, my meter 2 is attached to more than just my apartment, and I will call the landlord out on it.
However, my real concern now, is this setup looks quite unsafe to me, and it is located about 2 feet from the only exit door out the building. Then, I am not an expert. Am I wrong?
Here are some photos
Very untidy, and hard to see what’s going on.
To me, those wires don’t look big enough to carry the entire current for each apartment, and may just be some control circuit to switch in different tarrifs…. The main heavy cable being enclosed within the trunking.
The black metal box may be a thermostat for heating.
Do you have any equipment to know if there’s power in any of those wires? As it could be some redundant set up that’s not doing anything at all.
The meters obviously work… but no, this isn’t “safe”
The outcome of speaking to your landlord about it could be variable, depending on their attitude to such things and your present relationship.
Reply to the thread, titled "Is this even safe?" which is posted in Electrician Talk | All Countries on Electricians Forums.
