Is this junction box up to codes? | on ElectriciansForums
Discuss Is this junction box up to codes? in the DIY Electrical Advice area at ElectriciansForums.net
AE Hammer
USA
Good day. Is there something wrong with this junction box (code violation) for a wall fixture? It is secured to studs. Old construction. Need it for a heavy fixture (16lb), usual boxes are rated up to 10 pounds and I don't want to cut the wall to install wood support. Previous fixture was installed without a box. The only thing I can see is that three wires are separated, not inside sleeve, but it was like this before. Previous fixture had splices inside the wall cavity and ground wire was disconnected. That is how it came came from the builder. House was built in 1997. Thank you.[ElectriciansForums.net] Is this junction box up to codes?
Good day. Is there something wrong with this junction box (code violation) for a wall fixture? It is secured to studs. Old construction. Need it for a heavy fixture (16lb), usual boxes are rated up to 10 pounds and I don't want to cut the wall to install wood support. Previous fixture was installed without a box. The only thing I can see is that three wires are separated, not inside sleeve, but it was like this before. Previous fixture had splices inside the wall cavity and ground wire was disconnected. That is how it came came from the builder. House was built in 1997. Thank you.View attachment 110345
You can go to Lowes or Home Depot and purchase a ceiling fan box which has a brace that you can adjust to the studs without having access to the attic.
Sorry for the late reply but welcome to the forum and good luck
Reactions: DPG
Reply to Is this junction box up to codes? in the DIY Electrical Advice area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
