Hi im sure this is notifyable just waqnt to check as im not with any body like nic or napit so will have to get lbc in and pay ÂŁ150 for them just to go that looks ok
I have to put a light and a socket in a garage that is 3m away from the house.
I was going to take a fuse spur from the upstairs ring the in plastic conduit into the garage then a fuse spur for the light but they want the light switch on the outside so will be ip rated
The cu is Rcd
The cu is Rcd
