I have this scenario: 2.5 mm SWA goes out from the CU and clamped direct on to the external wall into a water-tight plastic box (meant for this type of connection) and connected to the SWA cable coming from the garage – the connection is made using a JB. Does the REG objects using a JB inside that kind of box for external connections? Is there anything else available?
With the current arrangement I find it more protected against splash or leakage than using one of these from
If you're feeding a SWA into any enclosure I'd would use glands without thinking about it.
Some say, I've read it on here somewhere, you don't have to use glands! Totally bad practice in my eyes.
or have I completely misunderstood your problem?
Wouldn't be the first time!
Cant see a problem with a jb inside a wp box as long as the terminations are accessible, just looks odd. As suggested before why not just crimp the cables inside the box? and ensure the earth continuity of the armour.
London
Website
http://www.brithome.com/
Is this OK?
Thread Tags
Goody,
truckster,
