is this right | on ElectriciansForums
Discuss is this right in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
norfolk
[ElectriciansForums.net] is this right
this pic is in our book about what to and not to earth on our pv course does it look correct with regards to the bottom sections about needing a stake or not
thanks mark
That diagram has been copied from the similar decision tree in the DTI PV Installation Guide v2
It looks to contain the same information to me.
This is the original.
as i know less about PV installations than i do about open heart surgery, i won't comment.
What it is saying is this.
IF you need to bond the array frame at all then:
- if the grid supply to the premises is PME then install an earth spike and bond the array frame to the spike
- if the grid supply to the premises is NOT PME then bond the array frame to the MET
Suggest you download a copy of the DTI Guide and read the relevant section. There is a link to it in the PV Guide sticky post in this section.
http://www.electriciansforums.net/photovoltaic-solar-panels-green-energy-forum/23511-pv-guide.html
thanks mate thats a better way to explain it makes sense so as not to take an earth outside the zone
Reply to is this right in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Thank you! I didn't realise the wiring was QUITE that old… I'll replace it carefully.
We’ve recently completed the first and second fix of a barn conversion that is off grid with solar PV, batteries and a back up generator. This...
