Hi everyone. I just had an electric toilet seat installed (bidet - warms and shoots water, heats seat, etc). I think some protection was installed on the cable run (rcd?). However I noticed under the cistern some tape was used with the toilet seat cable and main electrical supply.
Is this safe?
Here's a picture:
Thanks to anyone who can help.
sounds like it’s outside the zones, or sounds like it’s a big bathroom!
sure that’s not 2 FEET from the shower?
That connection should definitely be in a box, especially if mains voltage, but it could be ELV without being able to check.
Rough as a badgers.....
Better check it has an RCD and it’s tested frequently.
Yes 2 metres, it's a wide bathroom, the shower and toilet are on either side.
ELV? I'll send a pic of the wires with tape unwrapped too when I get home.
Yes. Please do not unwrap the tape.
is there a rating plate on the appliance, or do you have the instruction book. It will say if it’s 230v or 12 maybe 24v
I must say I haven’t seen many recently installed connector block n tape joints , most are a few years old at least.
Have come across quite a few wago tape joints recently thou.
Especially on new builds with lots of down lights. Come across loads of taped up wagos.
Clearly the boxes are far too expensive...
Is this safe?
Here's a picture: View attachment 62596
UK
United Kingdom
Is this safe?
Tre390,
telectrix,
