Discuss isolate manes in the UK Electrical Forum area at ElectriciansForums.net
the switch serves onlhy my flat but I dont know if the switch is between the supply and the metter ot between the metter and cable is going up to feed my Consumer Unit. I am confident to change a consumer unit but I have no idea what is a EIC. Please reveal to me about this enigmatic term : EIC. Thank you
Ict. Ty
but if I think logically, this switch is operative with the purpose of being operated, and there is no barriere or restriciton to its operation. SO I would assume I can operate it
Again, this is why you should not be doing it. An electrician does not assume anything. An electrician would trace out what is feeding what and would know what it is feeding. I expect you are going to do it anyway so you will soon find out.but if I think logically, this switch is operative with the purpose of being operated, and there is no barriere or restriciton to its operation. SO I would assume I can operate it
Ask Admin to join the trainee section on here. Hang fire on changing your fuseboard for a bit. You will be much better placed to do it once you understand a bit more of what is required.I 100% agree with you about all accurate and thorough tests. Would you be interested to assist me (via internet) with the testing? I have my 1653B Fluke tester and I will find somewhere some papers to write the resaults.
Reply to isolate manes in the UK Electrical Forum area at ElectriciansForums.net
