Isolate ring main extension. | on ElectriciansForums
Discuss Isolate ring main extension. in the DIY Electrical Advice area at ElectriciansForums.net
Sboyuk
Lancashire
Hi all,
I hope you can help, I'd like to extend a ring main into the an outbuilding and be able to isolate it if required.
I'll be using power tools and wanted about 4 double sockets in there so didn't want just a spur.
I've attached an image, is this an acceptable way of doing it.? The live and neutral wires would be joined where they enter the switch so as not to break the existing ring so the new ring will be taking power from both cables of the existing ring. Many thanks. Steve.
  • [ElectriciansForums.net] Isolate ring main extension.
P. S When I say the live and neutral wires joined coming into the switch obviously I mean each side of the live joined and each side of the natural joined.
Reply to Isolate ring main extension. in the DIY Electrical Advice area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
Luckily when I rejigged the socket to fit the fcu next to it, it meant the original ring wiring reached, i put the socket on the ring and took a...
