F
Fender
Hi all, is it sufficient to turn off the switch to the boiler when doing an IR test? I thought only double pole switches would isolate both phase and neutral and a boiler ran off a fused spur isn't double pole? Dimmer switches you disconnect and join phase and neutral, do you do this at the fused spur when isolating the boiler.
