H
Harry Pay
Hi can anyone help please. I have installed a 1.75 kW system with a Solar river 1600 TL inverter. It worked fine until a recent SSE cable failure in road. Since then I get an isolation fault on inverter. I have tested each panel which give ICS and voltage as you would expect and carried out Insulation resistance tests on panels which proved ok. Solar River have replaced the inverter but I still get Isolation fault on new inverter. Is there anywhere on AC side that could cause this fault
Happy days Bob
Happy days Bob
