Ay up lads
I'm about to install 10mm2 5 core swa for 63 amp chiller protected by 63a MCCB, should I provide rotary isolator for it? Chiller must be working 24h/7
Its my first industrial install and probably my pay rise depend on it. I know there is the reg saying "means of isolation shall be provided" but the chiller needs to be permamently on and powerd up through a 5pin plug. Can you help guys?
Ay up lads
Fit a switched 5 pin socket outlet, capable of being locked in the OFF POSITION. With interlock to st an inadvertent removal of the plug on load.
Cheaper to just fit a rotary isolator. Why install a socket? If this machine is to run 24H it's hardly something portable. It'll be fixed in place with pipe work and heat ex changers.
Edit: Sorry, I miss read the OP. Didn't see it came with a plug. Even still, I would take it off and wire into a normal rotary isolator installed next to the machine.
I would keep the plug, reason although hopefully you would have carried out the safe isolation correctly, the sight of a plug dangling by the machine would give you greater confidence that the machine was in fact isolated, in my opinion anyway.
Heathrow
Isolator for 63A chiller?
Talk Electrician Forum
Thread Tags
Tags Tags
isolator
Pawel505,
Pete999,
