View the thread, titled "Isolator in the outdoor electrical box" which is posted in DIY Electrical Advice on Electricians Forums.
Hi there,
I'm planning to replace the MCB on my outdoor electrical box with a better quality one, and since there is already an isolator installed by ESB Networks, as a DIY I can safely do it myself. My question is, about the isolator marked inside the orange circle. Does anyone knows what key should I use to rotate it to the OFF position and is there any safe procedure for that I should be aware before touching it?
Any advice on this would be greatly appreciated!
Thank you in advance
These are Restricted Electrical Works. You must not interfere with the Main Overcurrent Device. By doing so you will be committing a criminal offence which is punishable by a fine of up to €50,000 and/or three years' imprisonment.
Only a Registered Electrical Contractor (REC) can carry out these works.
Reply to the thread, titled "Isolator in the outdoor electrical box" which is posted in DIY Electrical Advice on Electricians Forums.
