Looking to fit an isolator switch before consumer unit, anyone have any recommendations and/or links? Cheers
Discuss Isolator switch in the UK Electrical Forum area at ElectriciansForums.net
Can't believe we're still left wondering what's the correct way to go with it.
The regs to say what to use. Yes, we all know its OTT and the DNO will just fit a plastic one if they do the job.
This as all come about due to limp wristed """electricians""" not being able enough to terminate a fuse board!
Had the DNO out to a new build bungalow a couple of weeks ago and they installed the same unit from memory.
I'm sure I've seen a metal clad version and talk on here about it, been on the phone to wholesaler this morning they don't have a clue and don't have anything metal!
Apparently a main switch fitted by the dno does not fall under the requirements if bs7671 rather the esqr regs hence thats how they get around the need to fit a non combustible enclosure.
Ah, but if you read the DNOs own design specifications they say that any of their equipment on a consumers property needs to meet 7671 requirements
Reply to Isolator switch in the UK Electrical Forum area at ElectriciansForums.net
