Issue with cat 6 connection | Page 2 | on ElectriciansForums
Discuss Issue with cat 6 connection in the UK Electrical Forum area at ElectriciansForums.net
Sb8389
Nottingham
Hey guys
I installed a cat 6 ftp cable last week around 50metres. It goes from one cat6 faceplate to another. When I originally tested the connection it was fine with my network tester,we tested with a couple of cat 5e patch leads to check connectivity and was fine. Today the customer has brought a couple of cat 6 patch leads and re tested (getting no connection). I popped out tonight and tested the line with my tester and getting nothing, would you point towards it being a module issue as the tester would pick up open circuits so I know it’s not that.
From your experience what would you guess it could be.
Have to ask if you've confirmed the tester on a known good cable? Those Screwfix (Philex?) testers aren't super reliable. Either way you'll find out when you buzz the wires.
I know they ain’t the best, but did check the patch cables I was using to check continuity and all ok, like you say bell them out and see where I am at with it.
Check the patch leads to see if they are standard cables or crossover leads and check each cable separately whilst disconnected.
What tester are you using as I used to use a Fluke Link Runner for integrating cable runs and port locations.
FLUKE NETWORKS LinkRunner AT 1000 Network Auto-Tester - The fastest... - https://www.comms-express.com/products/linkrunner-at-1000-network-auto-tester/
Bit more advanced machine than the philex network tester from Screwfix pal haha I shall check the cables when I go back. Thanks for the advice
Quite informative PEG, what 28 continuity tests would you carry out to ensure all is ok.
These
[ElectriciansForums.net] Issue with cat 6 connection
I had a similar problem,it worked,then weeks later failed.
I changed the data module,re connected,& ok....fingers crossed.
Don’t know about you,I kinda loose it a bit on these connections,not really knowing the in’s & out’s.
Hi,i would have carried the most basic of tests,using whatever AVI or resistance measuring device i had to hand,and would have an indication,before i had tea,whether or not it was O/C on one or all conductors.
Before i did the above,any multi-continuity or TDR type testing,i would do the following....make sure,i had the two ends of the same cable,EVEN if i fitted it initially...i would walk the route,giving every inch,a good,hard Paddington bear type stare,to look for clues.
I would be assuming the worst - and then discounting it.
....Maybe someone pulled a t&e,through one of your holes/conduits....maybe it was tight,and they pulled back and forth,and sawed through your cable,and now,one of the live conductors,is bridging or has severed,the CAT cable...
It is unlikely,but can happen,as i have seen it happen,so get stuck in,be thorough,be successful,maybe even be a hero....but sort it,invoice accordingly and then..........relax:cool::)
Reply to Issue with cat 6 connection in the UK Electrical Forum area at ElectriciansForums.net
