Issue with my Fluke 115 Meter... | on ElectriciansForums
Discuss Issue with my Fluke 115 Meter... in the Electrical Tools and Products area at ElectriciansForums.net
HumbleWorker 91RT
Trainee
Manchester
Hi guys and girls,
I am having a slight issue with my multi meter,
its display has randomly flickered whilst on voltage then the continuity buzzer just went off.. and the screen crashed.
I have a feeling it's shorted internally due to the strange behaviour, when I use the rotary to turn it off then back on it resets...
I must also say I haven't had it calibrated since I first got it three years ago.
Anyone had a similar issue?.
Cheers,
HW
If it hasn't been used much then there may be dust/dirt in the rotary contacts. Have you tried rotating the dial a number of times to wear away any surface grime? Can you get into it with some contact spray?
Murdoch - do you have your multimeter calibrated? MFT yes but multimeter?
Hey RPA,
Yeah I've been using it the past week quite a lot so it's usage should of sorted out any sort etc banana ports seem clean and sprayed contact clean on them
Reply to Issue with my Fluke 115 Meter... in the Electrical Tools and Products area at ElectriciansForums.net
I am living in the north of Thailand outside of the big city. That means in the rainy season we have multiple times per week power outages...
