Issues With Nest Generation 3 Operating Boiler? plumbing advice | on ElectriciansForums
  • Thread starter Dulbert
  • Start date
  • Replies 0
  • Views 74
Discuss Issues With Nest Generation 3 Operating Boiler? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Issues With Nest Generation 3 Operating Boiler? I have a Google Nest Generation 3 Thermostat/Heatlink, Thermostat is in the hallway and operates non hard wired, Heatlink is upstairs in the airing cupboard. There is also a Mains Link fitted for the boiler over run.
I have an intermitant problem when the stat gets turned up it glows oranges like it is calling for heat but the boiler does not fire.
Also, when the boiler does fire it intermitantly will not shutdown when the stat is turned down although tthe stat goes grey like it has.
It has worked perfectly for over a year since a full new installation of control system and boiler etc
Now currently chasing Google Nest who will hopefully give me a code so Boxt will return and exchange for a new one.
System works fine with Hot Water every time.
Issues With Nest Generation 3 Operating Boiler? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Issues With Nest Generation 3 Operating Boiler? plumbing advice in the Plumbers Forums area at ElectriciansForums.net
H
Boiler Programmer I have a wall mounted thermostat which is connected to a 26 volt supply from my Glowworm 24ci boiler. I would like to replace...
homebrewer55
H
Yes I think back in the dark old days they were called deeds but are now called contracts and some still refer to it as deeds like I did! Sounds...
