davetherave1979
Hi Guys had a look at this job today 30 computer stations they dont have computer towers at each desk just a monitor and a box that talks back to the main server going to split the circuits up got to fit a new db and will fit rcbos to each circuit would I be best wiring 20 amp radials or 32 rings there isnt much load. there will be 6 circuits around the room I was going to wire in 4mm te and run a clean earth circuit to each circuit in 4mm singles as this will be for the high protective conductor does this all sound correct.
Normally only do domestic and small commerical work havent wired a ITC suite before as work is dead I need this job and they say there is more through the holidays.
Any help would be great:rolleyes2:
