Its a tricky one! | on ElectriciansForums
Discuss Its a tricky one! in the UK Electrical Forum area at ElectriciansForums.net
neil12345
Wales
Hi all,
hope you are well, DIY'er after some thoughts if possible. After a period of very heavy and prolonged rain my electricity trips, when I turn off the switch for the power to the shed (pic attached) I can put the electricity back on.
Sometimes I can then immediately put the shed switch back on and all is well, sometimes I need to leave it a few hours before it will go back on without tripping. When it is at a stage where it won't switch on without tripping I've turned off sockets, lights etc in shed and it still trips when shed power is switched on.
That would make me think the the issue is with the armored cable that's mainly buried under soil, however what I don't understand is that if water is getting into the cable and causing a trip why would it all be OK again, sometimes immediately, sometimes after a few hours as the ground, let alone the cable, won't dry out in that time?
Any thoughts as to what could be causing it or any further steps to diagnose?
Thanks all, any input hugely appreciated.
[ElectriciansForums.net] Its a tricky one!
First thought is water ingress into the equipment in the shed.
Is it a substantial brick built outhouse, or just a shed?
Domestic style white plastic fittings are not really suitable for in a shed.
With the power off, completely, to the shed…. Remove the face screws and look behind any switches and sockets. See if there’s water.
Hi all,
You are only switching off the Live so if it is a N to CPC leak it will still trip.
How is the armoured terminated? do you have an external box to that wall? As littlespark said check for water leakage at all junction boxes and accessories and fittings before suspecting the armoured cable itself. Check anything external first as that is the most likely.
And obviously follow safe isolation procedures.
Reply to Its a tricky one! in the UK Electrical Forum area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
Ok I’ll try this when I’m down
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
If you think that's bad you should try manually winding out the safety curtain in a theatre.
davesparks
A faulty element was my first thought of most likely culprit. however, if the big red cooker switch is turned off and the issue with the electrics...
