It's the weekend so.... | on ElectriciansForums
Discuss It's the weekend so.... in the UK Electrical Forum area at ElectriciansForums.net
Not if they are in the bathroom (and its RCD protected)
No,because I am not working with cable tray,but
My thoughts are,most situations probably not,but
If the specs asked for them to be bonded then bonded they will be,but
I would say that they also need bonding if they enter/exit a building
Wouldn't cable tray be an exposed conductive part, assuming you can touch it??
Exposed-Conductive-Part – Conductive part of equipment which can be touched and which is not normally live, but which may become live under fault conditions.
If there was an Insulation resistance fault with a cable on cable tray, there would be potential of it going live, so personally I would bond it, but it could be out of reach??? meaning it can't be touched and doesn't require bonding??
Either way, I would still bond it to be safe.
If it was deemed to be an exposed conductive part then you would earth it not bond it.
You think it is a good idea to bond a tray where it passes from a building, maybe into another.
Exactly what I have been reading haha. I didn't even know you can get bare MICC until I read that. Allways thought it was in an orange sheath.
Allways learning, that's what I signed up here for :)
I have installed bare, orange, red, black and white. Pay the manufacturer enough they will probably do you some pink.
Reply to It's the weekend so.... in the UK Electrical Forum area at ElectriciansForums.net
They are excellent, I have used them a few times for consumer unit relocations! They can get a bit tight with cables if you're using all the...
Thats a freak accident though, it could just as easilly been anything that killed him. It could very well have been a double insulated bench...
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
