I've finally done it......... | on ElectriciansForums
Discuss I've finally done it......... in the Business Related area at ElectriciansForums.net
kevyn
This is one for all the scottish sparks as i will need some advice please.
I have applied for my ACA for regrading to approved status. Does anyone have any advice on this assesment? :confused:
ACA is the Advanced Competence Assessment. I need to do this before I can join the NIC or Select etc
Done mine a few years back.
All based on safe isolation and testing procedures, there is also an open book test on various things like the above and also sort of foreman type related questions ie would you get a spark/apprentice/labourer to do certain tasks.
Try and get some hands on testing and read up on guidance note 3 that should set you up for it. They should also send you out a booklet which shows you the booths containing the layouts that you will be testing/isolating.
Reply to I've finally done it......... in the Business Related area at ElectriciansForums.net
The coding part is all down to experience and knowing whether something is right or wrong. Remember some pics have no faults.
R
Radiator advice Hi was looking for some help, I am looking to change out a radiator in my Hallway, my issue is the center of my pipes to the...
rclark1110
R
